Low end miss or pinion angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2013, 02:57 PM
1962 Chevy Impala. From a standing start I get a "fish bite"....shutter upon acceleration. Tried power braking and *** seems the engine might be missing when I feed it gas. Other than this the car runs great. Don't know if there is something in the initial engine timing or the pinion alignment. Currently it is set at 3* to match the engine angle. Any suggestions?
Old 07-06-2013, 04:55 PM
techinspector1's Avatar
Wiki Edits: 326
Matching pinion angle to trans angle (3* up bubble for pinion, 3* down bubble for output shaft) will work well under light power applications. Under extreme power applications such as you are suggesting, the pinion will climb the ring gear and there will no longer be a parallel match between the trans and the pinion. The looser the suspension (parts worn out), the worse the difference between the trans and the pinion can be. It is possible to begin breaking parts if you don't correct the problem.
After getting the whole mess under control with new parts and tightening up the suspension, I would change the pinion angle to zero or 1 degree up bubble, so that under power, the pinion would climb a little and zero out the two angles.
Old 07-06-2013, 11:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You sure you don't have broken motor and/or tranny mounts?
trans. angle /pinion angle adjustments ? rf9763 Transmission - Rearend 6 09-24-2011 03:02 AM
pinion angle up or down? db flyer Transmission - Rearend 15 01-15-2011 08:25 AM
Low rpm miss 1969NovaSS Hotrodding Basics 3 07-24-2006 06:42 AM
pinion angle mad55chevy Transmission - Rearend 3 09-09-2003 06:55 PM
