Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Low idle oil pressure
Old 03-02-2003, 08:03 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post
its common for one or two rockers to decorate the fender and walls on a small block, thats why they make "rocker stoppers", have you tried a different gauge? or maybe the line is partially plugged? Did you put in new cam bearings on the rebuild? what kind of main bearing clearance?
