-   -   low idle vacuum question (http://www.hotrodders.com/forum/low-idle-vacuum-question-171046.html)
40forddgc 01-05-2010 06:38 PM
I just put a new 350 cubic inch in my 40 Ford. It runs really well. It has a new 575 dual feed Holey. At low idle it has 5 vacuum and under load it has 15 vacuum. My question is why is it dying at low idle?
Thanks
Doug
cobalt327 01-05-2010 06:47 PM
Thanks
Doug
The needle of the gage is steady, but low at idle? It might just be a question of where you are sampling the vacuum at. If it's from a ported vacuum source, it could behave the way you describe.
Otherwise, check for the initial timing being low, vacuum leaks, etc.
An undamped gage is better for diagnosing engines with- it allows the needle to move at the least provocation.
