low idle vacuum question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2010, 06:38 PM
40forddgc's Avatar
I just put a new 350 cubic inch in my 40 Ford. It runs really well. It has a new 575 dual feed Holey. At low idle it has 5 vacuum and under load it has 15 vacuum. My question is why is it dying at low idle?
Thanks
Doug
Old 01-05-2010, 06:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
Doug
The needle of the gage is steady, but low at idle? It might just be a question of where you are sampling the vacuum at. If it's from a ported vacuum source, it could behave the way you describe.
Otherwise, check for the initial timing being low, vacuum leaks, etc.
An undamped gage is better for diagnosing engines with- it allows the needle to move at the least provocation.
vacuum gauge readings GMR Engine 11 08-25-2008 12:03 PM
Edelbrock 750 tuning GCD1962 Engine 42 04-16-2008 06:03 PM
350 sbc will not accelerate j_sirnio Engine 15 02-06-2008 09:55 PM
68 charger lights T-bucket23 Electrical 5 08-14-2006 05:07 PM
at wits end on ford brakes....... crazy larry Suspension - Brakes - Steering 30 04-06-2004 05:39 AM
