Low Mile Turbo 400 Been Sitting For 7 Years What are the chances it still works? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2010, 08:45 PM
heathj1's Avatar
Which way to the swap meet??
Found a turbo 400 for my g body project guy says it has 10k on rebuild and has been sitting for 7-8 years in his unheated shop. So what are the chances that I could bolt it in with new torque converter filter and oil that it would work? The guy that wants to sell it to me says it still full of oil and has been inside all the time. He want $175 for it. I know the guy and don't think he would BS me.
I know you don't have a crystal ball just give my your 2 cents. Thanks
Old 04-03-2010, 09:50 PM
bentwings's Avatar
bentwings
My T-350 sat for 6 years after rebuilding. I just filled it with ATF and started up the motor. No problems at all.
Old 04-03-2010, 10:32 PM
I'm using an original 1978 TH400 in my 79 that has been sitting most of the time since 05. It was driven maybe a handfull of times before being pulled in 06 and had been sitting outside under a tarp ever since until recently. It still works just fine. It even got wet a time or two (i power washed the heck out of it) and it never did get any water in it.
I was quite surprised to be honest. And this was on and old well used TH400, let alone a low mile rebuilt one. Id say youd be fine with it.
Old 04-03-2010, 10:49 PM
sqzbox's Avatar
My pipes are my music
reserection
There's one thing you need to do for sure while it's out of the car.
Replace the front seal (for the torque converter)
More than likely, they have both gotten brittle with age and it's better to be safe than sorry as it's no fun pulling the tranny right after you install it to replace a leaking front seal.
The rear (yoke seal) can be done after the installation if needed.
Old 04-04-2010, 01:30 AM
junior stocker's Avatar
After I put a TH400 in my truck, in place of the TH350 it had in it, I had to go right out and buy another TH400, I was that impressed with the first one. Now I have a spare, or one for a future project. The second one I bought was just rebuilt for the truck it was in, then the truck was wrecked. It sat under a guys deck for a while. I replaced the front and rear seals, drained the fluid out, stuck a new filter on it (it also has an aftermarket pickup that takes a Chrysler 904 filter),new pan gasket, cleaned and painted the pan, and sealed it up. There was a dime sized glob of "sludge" under the filter; other than that it looks like new inside. $150.00 for the trans! The guy told me it also has a "shift kit", and threw in the driveshaft. So, replace the front/rear seals, remove the pan and clean it out, replace the filter and pan gasket. Butch/junior stocker
Old 04-04-2010, 03:17 PM
heathj1's Avatar
Thanks Guys!!!
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Choose Pontiac 400 or 455? & Turbo Questions TheMonkey Engine 33 08-11-2009 11:01 PM
65 skylark turbo 400 trans. install question skylark65 Transmission - Rearend 7 05-09-2007 09:29 PM
