Who rebuilt it? How long ago? Sounds like possible main bearings are worn out.. When warm does it start tapping some? The mains might be down to the copper causing weak oil pressure ..If its a fresh build how was the mains installed?
The engine runs like a champ, nothing sound or feels wierd at anytime whether it is idling or I am putting the hammer down. I have noticed that there seems to be a very small oil leak, as I now have a couple spots on my garage floor about the size of a nickle. I have now idea were that is coming from either... At this time tho I am not really concerned about the small oil leak, as it is extremely small. but the oil pressure does bother me. |
I wouldnt be to worried about it.20 lbs after warm up not really to bad you said it goes up when rpm go up.i take the 20 lbs is at idle.is it 40 to 45 when driving .when sitting still if you rev the engine does it climb higher then 45. cole
here something you can read from here.maybe it will help. Small Block Chevy Oil Pressure cole
you got it, gets as low as 20 when idling and gets back up to 40-45 when giving it some rpms. when at idle and i rev it doesnt quite come all the way up to 40 but right there pretty close to it...
I dont think you have anything to worry about. but i would keep a eye on things its not making any noises. it would be nice to know what brand bearings are in the bottom end and what oil pump was installed when it was built. cole
Sounds pretty normal to me... if you are concerned go with a heavier weight oil, maybe a 10w-40 instead of the typical 10w-30. Just to make sure there's no knocking at any point in time right?
sounds to me like the oil filter isnt on right. i had the same problems and when i changed the oil i noitced that the filter wasnt on tight enough. that could be why its leaking too. not a big deal though.
it's bored .060 and the stock radiator still . it gets hot and won't cool down unless you turn it off . after a hour , 40 psi again on oil . i use that lucas in mine and 20 -50 oil . been romping since 1979 and still going strong . maybe your running little on hot side . |
Sounds normal. With a standard pressure pump, pressure gets kinda low at idle at temperature.
I'm running a SBC .030 over, fresh clevite bearings all around, running 0W30. Once the block comes up to temp, it's a combination of the pump pressure and the viscosity that causes a low pressure condition. I have a low pressure warning light (autometer 3-way warning system) that triggers below 25psi, and it frequently comes on at idle after the block is at temp. Another thing you might check is the sender unit or the mechanical line tap that's feeding your gauge, make sure it's reading accurately. the blonde weasel |
brad,
"where" the sender is mounted on the oil galleys is likely the cause for what you are seeing.... your reading the "remaining" pressure after the pressure drop from bleeding oil at the main and cam bearings... you have 20psi left going thru the pushrods to the rockers at idle and that's more than plenty when the motor is warmed up.... the pressure climbs with rpms because the pump gpm increase exceeds the basically constant bearings bleed gpm rate... |
Cool, thanks to everyone for the good feedback. I am happy to know that this is a common occurance and not something I should fret about. I will let yall know if something changes.
Thanks Again |
| Troubleshooting low oil pressure? | dfdubb | Engine | 19 | 03-13-2007 10:24 PM |
| lets have a oil pressure discussion | k-star | Engine | 9 | 02-05-2007 11:31 AM |
| oil pressure switch | Blob | Engine | 7 | 12-02-2005 12:34 PM |
| low oil pressure, but no bad engine noise | Ledslnger | General Rodding Tech | 15 | 11-30-2003 09:30 AM |
| low oil pressure | corona jon | Engine | 2 | 09-24-2003 08:29 AM |
