low oil pressure problem, main bearings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2008, 05:08 PM
Is it possable to check my main bearing clearence by just dropping the pan or just figure on a weekend engine pull party.
Old 11-05-2008, 05:11 PM
Jmark's Avatar
You can pull the pan and ck the bearing clearances with plastigauge. Not the best but does work.
Old 11-05-2008, 05:29 PM
Oil pressure
Thank You I recently pulled the heads to replace the gaskets.The combustion chambers looked good. The anti-freeze must have cleaned out the carbon. It doesn't smoke. The oil pressure is at 15 at idle but only 25 going down the road. It's a 400 sbc.
Old 11-05-2008, 05:52 PM
wildman1932's Avatar
Dave's hot Rod Shop
In the past, I have put a high volume/ hi pressure oil pumps on a tired motor and pick up good oil pressure. My old '51 had 2 lbs hot at idle, changed the pump and it has 30 lbs know.
Dave
Dave's Hot Rod Shop KC Mo
Old 11-05-2008, 05:55 PM
earl pressure
I think it'll make it through winter than I'll have an engine pull party.
Old 11-05-2008, 05:57 PM
I recently experienced a sudden drop in oil pressure on my 427 bbc., it turned out that debris in the oil pump pressure relief valve was holding the valve partially open resulting in a 20 to 30 psi loss in pressure.If you are lucky that may be the problem.Good luck...Ron.
Old 11-05-2008, 06:08 PM
Usually when the bearings are gone, it's the idle oil pressure that disappears not lower cruise pressure that happens. Pressure that falls as RPM comes up is generally indicating:
- That the relief valve has failed and is venting too much oil back to the pan.
- There is a blockage or leak in the pick-up.
- There is a blockage in the main oil galley or filter.
- There is insufficient drain back from the top end.
- The pressure gauge or its sender is lying.
Bogie
Old 11-05-2008, 06:20 PM
DoubleVision's Avatar
I agree with Bogie. Connect a direct mechanical gauge to the oil pressure outlet and check it.
high oil pressure HELP PLEASE! RDavis81 Engine 8 03-25-2009 06:44 PM
I need some help with my 350 Chevy engine... piniongear Engine 92 07-17-2008 12:57 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
tbi 350 oil pressure sending unit problem HELP orangebaja Engine 3 11-07-2003 07:23 PM
Oil pressure problem Tony Simon Engine 10 09-20-2002 10:06 AM
