Low oil pressure on SBC - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-30-2013, 05:00 PM
Originally Posted by TylerS10 View Post
Its a 355 1970's block 4 bolt main studded solid roller setup "new build" probably only about 1000 miles on it.
Machine shop said the pickup is welded and ensures me the pickup height is correct.
Pan: Hamburger's 1099
Pump: Milodon HV 18760
New mechanical gauge and copper hose
"Machine shop said the pickup is welded and ensures me the pickup height is correct."
Not really, it is a means of being sure the pickup doesn't leak air at the join to the pump and that it doesn't loosen in the pomp bore and move around. The height from the bottom of the pan is established by measurement of the assembly, hopefully done before any welding and then welded properly. Then there is the issue of weld heat to the pump housing, if left in during welding often the relief valve spring is damaged by the heat. The heat can also distort the casting.
Welding on the pump is not all that simple of a thing to do, it's easy to perform more damage than good.
Bogie
low oil pressure... gearhead81 Engine 13 03-12-2009 06:54 PM
fram oil filter lower oil pressure elvis 66 chevelle Engine 33 09-14-2006 04:36 PM
low engine pressure molevolent_creations Engine 14 12-24-2005 07:49 PM
Help 350 rocket bad timing chain & low oil pressure? 71oldsmann Engine 2 03-14-2005 11:45 PM
Low Oil Pressure on Buick 3.8L V-6 TravisT Engine 8 03-31-2004 10:12 AM
