Low oil pressure on SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2008, 12:56 PM
lg1969's Avatar
Google "Tunnel Ram 406"
A long time ago I had a problem with my 307 sbc with low oil pressure. I rebuilt the 307 with new crank bearings, and replace with a high pressure oil pump. Once I had the 307 together and had it running, the oil pressure was very low at 40psi cold, and 5-10psi hot. It should read 80 psi cold, and 40psi hot. I discovered the distributor was cause of the problem. The oil travel around the groove of the distributor housing then through the lifter gallery was leaking. I replaced the distributor with another one and to my supprise the oil pressure jumped up 80psi cold and 40psi hot. If any of you guys have low oil pressure on your sbc, before you take the block apart, check the distributor.
Old 10-24-2008, 02:51 PM
Jmark's Avatar
That's a good tip! If the dist. housing was wobbling around a little, over time it could loose it's size and leak a lot of oil right back into the pan.
Old 08-07-2010, 02:12 PM
what do you mean by the housing was leaking?? i have a 350 and has very low oil pressure. change the oil from 10.30 to 20.50 and pressure comes up everywhere. just wanted to check about the distrib housing. problem thanks
Old 08-07-2010, 02:14 PM
also on that note how old was your distributor that was the problem one
Old 08-07-2010, 02:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The distributor body forms part of the oil passage- that's the "groove" seen down near the gear in the photo below. If the dist. body was machined undersized or was damaged/excessively worn, this would create an internal oil leak from the groove that would dump oil back into the pan- and might also lower the oil pressure.
Old 05-28-2013, 12:23 PM
Damn I know this is a old post but I think this my be my problem also. New motor doing the same thing.
Old 05-28-2013, 01:27 PM
If you look at the picture above your post you will see the distributor has a grrove in the bosses above and below the oil groove passage. This is not necessary but probably isn't large enough to result in the problem.
You need to be sure the distributor is fully seated. If it catches the pump intermediate drive shaft just wrong, it will turn the pump but will be positioned to either obstruct the lifter galley and/or expose a leak back to the pan.
Bogie
Old 05-28-2013, 01:35 PM
lg1969's Avatar
Well, this problem happen to me again and it happen the second time on my 406 sbc.
Who says lighting does not hit you twice.
Old 05-28-2013, 02:26 PM
Now that I think about it my MSD 85551 had o rings and was told to take them out. Did not have this problem til I did that.
Old 05-28-2013, 04:56 PM
lg1969's Avatar
Bad mistake.
Old 05-28-2013, 04:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That might be an indication that your block was machined for use w/the O-rings; a factory production block isn't meant to use them unless modified for them.
BTW, the tops of the castings should be chamfered to allow the O-rings to slide into position w/o damaging them.
Old 05-28-2013, 06:01 PM
Yea that block came from a friend and was sitting for 10 years who knows what was done to it. 70's something block just said 350 on the casting. I had the machine work done a long time before I purchased the rotating assemble.
Old 05-28-2013, 07:03 PM
Richiehd's Avatar
JS-70
If I remember right, your motor was eating up distributer gears, that's why the o rings were removed. Maybe that housing is undersize, compared to a non oring housing?
Old 05-28-2013, 07:58 PM
Yea it was the end play on the gear that caused the timing to jump. The gear was walking up and down on the cam. I did that first and the o rings second when the new gear came in. The timing is rock solid now just the oil pressure problem now. Its always something so far.
Old 05-28-2013, 08:44 PM
Richiehd's Avatar
JS-70
10 psi for every 1000 rpms for SBC. I cut a small groove in mine and still have 30 psi hot oil pressure idling.
low oil pressure... gearhead81 Engine 13 03-12-2009 07:54 PM
fram oil filter lower oil pressure elvis 66 chevelle Engine 33 09-14-2006 05:36 PM
low engine pressure molevolent_creations Engine 14 12-24-2005 08:49 PM
Help 350 rocket bad timing chain & low oil pressure? 71oldsmann Engine 2 03-15-2005 12:45 AM
Low Oil Pressure on Buick 3.8L V-6 TravisT Engine 8 03-31-2004 11:12 AM
