What is the pressure reading?
Could be a number of things. most serious- bad bearings. restricted oil passage. internal oil plug leaking. New gauge bad. First I would try a heavier wt. oil and see if the pressure changes. If in fact the pressure is 0 at idle, you should not operate the vehicle. Usually on a warm engine, you should have about 10lb. pressure for every 1000rpm.
I would not go over say 10-40. When you changed the oil did you also change the filter. If not, try a new one.
