Low pedal - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2012, 06:19 PM
Low pedal
Here's one for you brake guys.
Will worn rotors cause a low pedal? I'm not talking about warped or scored rotors, I'm talking about the rotor thickness dimension being reduced. I'm not talking about a soft pedal, I'm talking about a low pedal.
What do you think?
BB
Old 12-11-2012, 03:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What do you think?
BB
In some cases, yes. The square cross section rubber seal between the piston and caliper acts as a return for the piston/pads by deforming when the piston is extended then returning to its normal state when the piston is no longer held extended by fluid pressure. This gives a running clearance, but if the rotor thickness were less, the pads could still retract as though the rotors were normal thickness. This is one reason that new pads often have shims w/them.
Because the caliper fluid volume is relatively large, any extra clearance between the piston/pad and the rotor translates into an increase in pedal travel.
Old 12-11-2012, 09:47 AM
S10xGN's Avatar
Gotta love a turbo!
Just to give an example of what Cobalt said about travel, my Excel brake calculator shows a 15/16" bore master cylinder at full stroke (pedal to the floor) will move each of my GM Metric front calipers 0.087". That's less than 3/32 of an inch!
Russ
Old 12-11-2012, 11:51 AM
Trucknut's Avatar
I ran into a "low pedal" problem on a 1969 Cadillac. It had drum brakes all the way around. Turned out that the drums had been turned too many times.
Mild RV Cam; low vacuum; low brake pedal knightline Engine 2 08-25-2012 10:57 AM
Low Brake Pedal MidnightFord Suspension - Brakes - Steering 2 09-05-2011 11:29 PM
low brake pedal bct Suspension - Brakes - Steering 1 11-15-2005 07:07 PM
Low brake pedal jpd37 Suspension - Brakes - Steering 6 06-15-2004 12:18 PM
Low Brake Pedal Bill Ford Suspension - Brakes - Steering 12 01-03-2004 10:43 AM
