-   -   Low pressure 700R4 (http://www.hotrodders.com/forum/low-pressure-700r4-58809.html)
AngliaBob 02-26-2005 05:57 PM
Low pressure 700R4
I bought a beefed up 700R4 in August. I was checking the pressure today, to calibrate the TV cable. I only have 55lbs in Park. Everyting I have read, says
the pressure should be between 90-120. If this is bad, what can I do to correct the situation?
Thanks,
AngliaBob
Crosley 02-26-2005 10:05 PM
raise the RPM ... see what happens
