Low Pressure Brake Switch Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2010, 08:49 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
I could have put this in two places but decided the electrical section was best.
My question is how the Brake switch should be wired, another sanity check.
I'm using the EZ Wiring harness and it contains two wires marked "brake switch power" (it's a heavy gauge wire) and another wire marked only "brake switch" (it's a much lighter gauge).
My question is does it matter which wire goes to which lug on the switch. (there are only two lugs on the switch with no markings) or do I just test the connections for proper operation once I apply power and step on the brake???
Any suggestions would be helpful... Thanx Guys...
Old 04-27-2010, 08:12 AM
302 Z28's Avatar
It does not matter which one has power as it is only a switch. If you are talking about this kind of switch. The two wires in your harness, one supplies power to the switch, the other goes to your brake lamp circuit and they feed through the switch
Vince
Old 04-27-2010, 09:24 AM
tc33's Avatar
Stuck in the 30's
Vince,
That be the switch. Thanx for the sanity check...
Old 04-27-2010, 09:34 AM
302 Z28's Avatar
Your welcome, glad I could help.
Vince
Oil pressure safety bypass switch boris_thespider Electrical 8 03-24-2010 03:41 PM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Starter switch stock to modified wiring question. Kallie49 Electrical 5 06-23-2006 06:01 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Low idle oil pressure chuckellison Engine 4 03-03-2003 07:20 AM
