Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #16
Old 06-08-2008, 06:38 AM
baddbob's Avatar
baddbob baddbob is offline
re: low priced spray gun/detail gun for primer/base/clear and ghost flames
Check out Astro for decent quality guns at cheap prices. The EVO has recieved excellent reviews.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "low priced spray gun/detail gun for primer/base/clear and ghost flames"
Ideas on Ghost Flames forestrytodd Body - Exterior 6 01-19-2008 09:47 PM
New Gun Needed for Ghost Flames? rockitdoc Body - Exterior 7 12-04-2005 10:58 AM
Ghost Flames Plan of Attack rockitdoc Body - Exterior 9 12-03-2005 08:31 PM
An Amateur Tries Ghost Flames rockitdoc Body - Exterior 13 12-02-2005 09:46 PM
Ghost flames chevyelc81 Body - Exterior 4 04-08-2004 07:10 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
