Low/Rev Clutch clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2007, 06:12 PM
Wich is the correct Low / Reverse clutch clearance? for a TH350...sorry....Thanks to all.....
Old 06-14-2007, 09:41 PM
jakeshoe's Avatar
It can be pretty wide, and you don't want it tight. It is being driven through in every gear except manual low or reverse.
.060" minimum to around .100" will be fine.
Old 06-15-2007, 08:09 AM
low/ rev clutch
In general, a good rule of thumb for clutch clearance issues is, about .010 clearance for every friction plate. Most times this will keep you out of trouble.
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 04:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 10:26 PM
56 chevy clutch linkage clearance jackfrost51 Transmission - Rearend 2 04-25-2005 10:52 AM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 08:04 PM
TH 350 Intermediate clutch clearance 1969Chevelle Transmission - Rearend 1 08-26-2003 05:34 PM
