low rpm engine vibrations...why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2003, 06:54 PM
Gearhead forever's Avatar
Post low rpm engine vibrations...why?
New motor, 800rpm vibe (truck at an idle..not rolling) but no engine noise audible. It started at about 400miles and seems to be getting a new vibe at about 1200rpm...under load. (now about 1400 miles) I'm thinking its an engine problem instead of trans because of the idle vibe. Any thoughts??? Please Help! Thanks.
Old 04-26-2003, 09:06 PM
woodz428's Avatar
Troll Hunter
Arrow
I'd check to see if you are hitting on all cylinders at that speed. A vacuum leak can cause a miss induced vibration that disappears as speed increases.
