Low rpm miss - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2006, 08:54 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
Low rpm miss
Today at work a coworker asked me to take a look at his car. Its a 84 el camino with a stock 305 except it has smog legal headers. It idles very rough. I tried to hold it at 2500 to see if it would go away and it didn't rant to rev and bog down while doing this in park. I messed with the adjustment on the the carb and it idled a little better.I held it at 1k and the needle jumped around like it was missing then held it at 2k and it was fine. the carb is a remand quadrajet. I couldn't check the timing as i didn't have my light with me but I will do it tomorrow. Does anyone know what else I should look at? any help is greatly appreciated.
Old 07-21-2006, 02:32 AM
boneyard Buick's Avatar
i had that problem with an 85 chev 350. And all i can say is TIMING. and get a new carb cuz the Quadra-Bogs arent worth the price of a rebuild kit.
Cya!
Ryan350 :thumbup:
Old 07-24-2006, 12:46 AM
Check the centrifugal advance mechanism (if it has one) for worn and/or sticking parts. Then there's always the phantom vacuum leak.
Old 07-24-2006, 05:42 AM
Make sure the plug wires are right and not shorting out
Whats wrong with the performer rpm cam?. 7fastelc0 Engine 19 12-09-2006 05:49 PM
Finally Fixed High RPM miss on the S-10 TurboS10 Engine 7 05-24-2005 06:40 PM
Raising the Redline Hollywooding Engine 23 07-17-2003 10:19 AM
87 Dodge 2.2 Turbo,bad low speed miss Spin Engine 2 04-22-2002 12:27 AM
Engine dosen't seem to have the low rpm grunt the old one had BadBowTie Engine 5 03-25-2002 03:52 AM
