Low throttle wants to die - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2013, 05:11 PM
62 ford 352 stock. Cold starts and idles fine, low throttle easing out of a stop causes back fire and hesitation. More throttle and WOT car runs smooth. Deceleration is fine. When I disconnect vacuum advance hose the exact opposite happens, low throttle is smooth, high throttle back fires and hesitation. Timing is at 8* per factory specs.
Any thoughts?
Old 02-09-2013, 10:40 PM
I feel like an idiot, point gap was out.
Low-throttle good, high throttle different story david-b Engine 6 05-24-2012 01:21 PM
89 tbi 5.7 running poorly no power at low rpm or half throttle monsterchevy355 Modern Electronic Engines 3 03-10-2012 08:25 PM
89 GM throttle body low vaccum on front ports of Throttle body martee373 Engine 9 02-04-2012 11:51 AM
Low CFM Die Grinder? mikeweb Garage - Tools 3 03-03-2009 08:51 AM
Throttle Control..Cable / Lever & Rod/ Or Electronic ( Throttle By Wire) Viet Nam Vette Engine 4 06-13-2005 05:29 PM
