Low on trany oil.... sliping trany? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2002, 04:11 PM
Question Low on trany oil.... sliping trany?
you may have read on another one of my posts, that I had a problem with a slipping trany(a Chevy TH350). I just put a new engine in my car after about a year got it running and noticed a leak in the trany oil cooler line( I fixed it) and now my trany is even lower on oil.
Could the trany being low on oil about 1.5pints from what I can tell on the dipstick make it slip some at first. and then not be much of a problem once warmer??
I was thinking It would, But I'm not quite sure.
One other Question, My owners manual said to use Dextron ATF, I have some DextronIII fluid Can I use it or is it a diffrent type?
Old 03-10-2002, 04:59 PM
dmorris1200's Avatar
doesn't play well with others
Post
I would top off the fluid and see if it still reacts the same. DextronIII should be what you need. We only stock DextronIII/Mercon for G.M.'s and older Fords, Type F(really old Fords), MerconV for new Fords, And 7176 for Mopars.
BUILT FORD TOUGH
Old 03-10-2002, 08:34 PM
Post
once again Dmorris to the rescue with the trany questions, Thanks for the Info! I was thinking that Dextron III would just be a (I'll say Upgraded) kind of fluid.
