Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Low Vacuum at idle - harsh shift
Old 05-29-2011, 05:58 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
vacuum modulator with red and black stripe are for low vacuum application.
harsh engagement into gear can be many things:
High RPM idle with tight converter.
Cushion plates removed from forward drum
PR spring from shift kit does raise line pressure.
Do not run vacuum line from a storage tank to the trans modulator. You need direct manifold vacuum
