low vacuum with power brakes, has anyone ever heard of hydralic assist. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2007, 08:10 PM
charger528's Avatar
I was at one of my local parts stores with one of my parts counter friends who during process of our bench racing cession mentioned something about installing hydralic assist on my brakes he says some big trucks and campers use them.
I guess my question is has anyone ever done this is there such a thing he also mentioned useing a vacum pump from a power stroke deseil as a evac system.
Old 09-22-2007, 08:17 PM
1930u's Avatar
Last journal entry: 1930u false floor section to hide A/C and Heater hoses
Some old 5.7 and 6.2 GM diesels used a system called hydraboost for power brakes. It works very well.
Old 09-22-2007, 08:36 PM
Wiki Edits: 31
Linclion was 1 of the first w/ hydraboost. uses power steering preassure to work.
Old 09-22-2007, 09:11 PM
brakes
Check out Hydratechbraking.com I installed one of their systems on a 1967 Camaro and it works great.
Old 09-23-2007, 04:44 AM
kruzr's Avatar
street rods forever
Summit Racing sells vacuum pumps for that,,,,,about 300bucks
Old 09-23-2007, 06:06 PM
Several GM motorhomes, and some other GM car models used an electrical vacuum pump. Do a google search and you should be able to find some reference articles on the net. One article I ran across had a list of GM models with OEM pumps, so that you could try to find one in a junkyard.
http://www.bdub.net/gmc-faq.html - scroll down to brakes
Bruc
Old 09-23-2007, 07:34 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
FWIW, Hydroboost brakes were not JUST installed on diesel-powered vehicles.
Be aware that GM swapped from 45° Flare fittings to Metric O-Ring in about 1980.
I assume that your Chrysler is also Saginaw pump equipped, but ... you will have to either "tee" into your existing return line, or buy a different reservoir with dual return line connections ... like this one:
NAPA # 20-8609
(One return port is for the PS and the other is for the HB.)
I am installing hydroboost brakes on my 66 GMC 454, and got almost everything I needed as remanufactured products from NAPA.
See my journal (entries 31, 32) for part numbers, pictures, and further explanation.
Old 09-25-2007, 12:21 AM
charger528's Avatar
Thanks for all info this may prove very useful in the near future
bill
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Convert to non power Disc Brakes John J Walton Suspension - Brakes - Steering 2 12-02-2004 06:46 PM
Low Idle Vacuum on 94' TBI Suburban edge Engine 4 07-21-2004 12:49 PM
