Lower ball joints - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2007, 07:02 PM
Lower ball joints
Hi guys,
Need a little advice. I'm changing lower ball joints on my S10. When pressing in the new ball joint it goes in VERY easy!! In fact they will fall out with a little tap! Both sides are the same. Napa says these are the right ball joint. What do you guys think? Thanks in advance.
Tommer
Old 09-04-2007, 11:53 PM
Wiki Edits: 27
locktite ?
have you cleane everything and tried a gell type locktight?
Old 09-05-2007, 02:33 PM
Check the hole in the A frame to see if it is worn if it is Moog makes oversized balljoints to correct this, or tack weld em in.
Old 09-05-2007, 06:23 PM
Lower Ball joints
I'm speaking as a professional auto technician that doesn't want to lose his business if someone gets into an accident because I screw up a ball joint installation.
The ONLY way to fix it is to replace the lower control arms. Use any other method, with the possible exception of the rumored oversize ball joints, and your necks in a noose if something fails. (I've heard about the oversize ball joints but never actually seen any that fit right.)
Old 09-05-2007, 07:51 PM
I agree with the last post, i'm a tech myself and wouldn't risk losing my job or someones life fixing cars incorrectly.
What I would do is take the ball joints back to napa and find someone who stocks Moog ball joints and get those. Carquest used to carry them under their name also. Just stay away from that cheap chinese crap. If they still dont fit than go get another set of lower control arms and put your moog ball joints in those.
Old 09-09-2007, 02:48 PM
I'll third what was said, and add that the stamped steel control arms can crack. Look for hairline cracks on the stamped boss that the ball joint presses into - a sure sign the arms need to be replaced.
Old 09-09-2007, 05:29 PM
Jmark's Avatar
Yep!!!
Yep!!!
And YEP!!!
lower ball joints stoney 81ta Suspension - Brakes - Steering 3 11-15-2006 10:12 AM
Shop time for lower ball joints montea Hotrodding Basics 11 08-11-2006 05:53 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Ball Joints....not a hot rod but.... screamin340 Suspension - Brakes - Steering 7 08-05-2005 03:51 PM
Ball Joints Question!!! bg Suspension - Brakes - Steering 2 03-31-2003 06:26 PM
