Lower Control Arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2007, 12:03 PM
71 c-10's Avatar
just a kid and his truck
Lower Control Arm
Quick question, is a lower control arm off 82 2x4 c-10 the same as on for a 71 2x4 c-10? Im pretty sure they are all the freaking same, but I cant find any evidence to prove either or. Thanks a bunch!
Old 03-29-2007, 01:01 PM
fast68's Avatar
likes chevy trucks & boobies
7yes and no,
it depends,
the bump stop is different 73-up than 71 and 72(the only two CST-era truck disc brake years)
and the shaft is solid on 72 and older -all trucks,
and solid on 73-up all -except 1/2 tons
in which are rubber
it is 4x2 technically
good luck
Old 03-29-2007, 01:08 PM
71 c-10's Avatar
uhh ok... a lil lost there, the bump stop, does not concern me, as it is being relocated and adjusted any ways, the control arm shaft bushings i assume your talking about, i can just get the right one for the era are right? But the physical arm is the same as it will bolt on and stuff right?
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Worn control arm mount FiveFeezy Suspension - Brakes - Steering 1 03-17-2007 01:08 AM
Control Arm Mounting Question joeford Suspension - Brakes - Steering 2 12-25-2005 10:05 PM
4th Control ARm????????? Toni Pepperoni Suspension - Brakes - Steering 1 02-06-2005 05:54 PM
upper control arm 67 C10 wickedwitchinak Suspension - Brakes - Steering 1 12-20-2004 10:47 PM
