lower control arm bolts
im getting ready to reassemble my front suspension on my 66 impala.
i have a copy of the factory assembly manual for reference, as i was looking through it i noticed that the diagram shows a lock washer between the rear nut and the rear cam plate on the bolt assembly for the lower control arm. the problem is that i don't have any lock washers for the bolts. and i don't mean i lost them because i was very careful to make sure i took all the hardware and reassembled the nuts and bolts with the parts so i didn't loose them and these would be big washers, around 1 inch. so there not easy to loose. the only marks on the nut or cam plate look round and smooth with a continuous groove not the little notch you would get from a lock washer. so the car was driven without the lock washers because they were never there to begin with. do you think i should get some and put them on or keep it the way it was????????????
you hit it right on the nose, im going to pick up a few tomorrow after work and start puting it all back together
| 62 Ford Galaxie Lower Control Arm Question | Rattpac | Suspension - Brakes - Steering | 2 | 11-05-2008 04:55 PM |
| Hoods not shuting all the way | 74_Chevrolet | Body - Exterior | 5 | 09-01-2005 07:10 PM |
| Door Alignment | Ron M | Body - Exterior | 2 | 08-21-2004 01:43 AM |
| Lower control arm bushings. What are the tricks of the trade?? | Jim Weeks | Suspension - Brakes - Steering | 7 | 05-11-2002 08:08 PM |
| rear lower control arms | oldsnut | Suspension - Brakes - Steering | 3 | 12-15-2001 09:01 AM |
