lower control arm drivers side c 1500 pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 02:03 AM
dwfleming
is the big bushing on the outside of a arm replaceable or is it factory made in the control arm?? any tips on this procedure would be appreciated. thanx!!
Old 02-18-2012, 03:16 AM
nine4gmc's Avatar
i got my bushings from oreilys for a few dollars each. first i tried what my neighbor said he did requiring a drill, various size bits, screwdriver, pliers and a BFH. took hours, literally but i got it out. the next one i wise'd up on and took the arm to the bench vice. it took me about 10 minutes to press out the remaining 3 bushings(i did both sides) and press the new ones in...
(edited)wait, are you talkin about the ball joint? either way, its replaceable too and probably just as old as the bushings so probably a good idea to add it to the list.
Old 02-18-2012, 07:38 AM
dwfleming
lower control arm bushings 1989 c 1500
thanks man you been a big help.
47 ford pick up cab drivers side door. GUTPILE Body - Exterior 2 02-26-2009 05:34 PM
Backfiring out of drivers side header? newdad1 Engine 14 10-25-2007 08:53 AM
backfire on drivers side of 350!??? "SLOWMOE" Engine 4 09-18-2005 04:29 PM
car 1.5" higher on drivers side brian400ex Suspension - Brakes - Steering 1 05-19-2004 04:29 PM
one side is1.75" lower than the other side. brian400ex Suspension - Brakes - Steering 15 04-01-2004 04:34 PM
