lower control arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2007, 08:53 PM
runn141's Avatar
lower control arms
i have an 87 s10 i have been building from the ground up. i installed new urethane bushings and new ball joints. now i have noticed that they do not match(lower control arms) and one is very pitted from rust(when i installed them they were all i had at the time) and one is letting the truck set 1/2 inch higher . now my ? is, is there a trick to get the ball joints out and reusing them? as for bushings they shouldn't be a problem, unless anyone has a suggestion
Old 04-28-2007, 05:56 PM
re:lower control arms
I was doing ball joints here in the shop not too long ago and after installing the new ones I found a crack in the lower control arm. I had one of the Boilermakers weld a 2 1/2" piece of pipe(diameter just enough to rest on the edge of the ball joint) to a piece of 3/8" plate cut to a near triangle shape so it would sit level in the space I had to work with and get a straight shot on it and used a hydraulic press to push it back out.
I don't have my camera with me tonight but if you want I'll bring it tomorrow and try to post some pics...
Bill
Old 04-28-2007, 05:58 PM
runn141's Avatar
i would appreciate that
Old 04-30-2007, 06:07 PM
Are you sure you still have both coil spring isolators in the frame spring buckets? If you lost one that end would sit lower.
Old 04-30-2007, 07:50 PM
runn141's Avatar
i have no isolators on either side, just something to cause rust. i guess i could use one on the lower side though.
Old 05-02-2007, 04:49 PM
re: lower control arms
I've got the pictures but they are too big to load. Anyone who needs to see them can PM me with your e-mail and I will gladly send them to you. I'll try to take some more pics at a lower resolution and load them in the next couple of days.
Bill
I put the pics of the tool I made for seating ball joints in the lower control arm on a newer model F-150 in my album.
I made this because the regular press would not pull the new ball joint into the control arm properly. I was told to set a piece of flat bar on top of the control arm and try, but the bar sat at a bad angle and didn't look too safe. I set this one(in the pics) on top of the lower control arm and used the press to pull the ball joint into place. The small piece of pipe welded on top keeps the clamp from shifting and the big one on the bottom sets over the hole.
I can't find the one I made to push the ball joints out with but it was the same except the bottom pipe was smaller in diameter and about 2" long. Using the ball joint press it will push the ball joint out without damaging it.
Let me know what you think...
Bill
Last edited by rebelbill1972; 05-02-2007 at 05:24 PM. Reason: Put pics in photo album
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Homemade boxed control arms FiveFeezy Suspension - Brakes - Steering 3 02-28-2007 08:53 PM
Chrysler Imperial lower control arm interchange powerrodsmike Suspension - Brakes - Steering 14 08-05-2006 06:08 PM
Narrowed Control arms? bonuts Suspension - Brakes - Steering 1 01-10-2006 07:50 PM
rear control arms for 69 chevelle mcgrsr Suspension - Brakes - Steering 3 01-22-2005 08:33 PM
