Lower frount end '41' Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2011, 06:43 PM
Is it possible to lower the front of my 41- 2"to 4" keeping the stock front end.
Old 12-10-2011, 07:34 PM
Wiki Edits: 27
longer shackels
My brother had longer shackles on his 40 coupe. but you can get more side sway with them ...they were the cheap alternative to a "DAGo dropped axle.
Old 12-10-2011, 08:53 PM
You can remove up to 3 leaves from the front spring and get a bit over an inch drop just from the thickness of the leaves removed. There will be an additional drop from the weakened spring. If you have had a motor/tranny swap to a SBC, there will be a slight weight loss and then motor may be moved some what to the rear which also reduces weight on the front springs. You can add better and some what stiffer shocks which will assist in keeping the spring from bottoming out.
Trees
Old 12-11-2011, 08:53 AM
BOBCRMAN@aol.com's Avatar
Speedway and Chassis engineering both sell a front crossmember that drops the ride height using stock axle components. Can't use a flathead ford engine tho.
33 Ford lower steering support Hot Rod Mike Suspension - Brakes - Steering 0 05-31-2011 06:32 PM
I want to lower my 53 ford truck! Help!! GUTPILE Suspension - Brakes - Steering 6 03-08-2009 11:29 AM
54 ford lower control arms fiddyfofoad Suspension - Brakes - Steering 7 07-30-2007 09:15 AM
got a qoeoestion about pinto frount end 38 old coupe Suspension - Brakes - Steering 4 06-04-2004 07:15 PM
mustang frount end Manley Body - Exterior 2 09-18-2002 06:51 AM
