Lower rad hose for a 32 with a SBF - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2011, 08:09 AM
Coming close to finishing my deuce roadster and could use some help on a lower rad hose. Rad is a Griffin with drivers side outlet on bottom. Engine is a late model 5.0 or 302 with a Ford Racing short water pump and inlet on drivers side. I have already cut up one hose that I thought was close but it won`t work. Any one else have this combination?
Thanks
Old 08-11-2011, 11:46 AM
Over 40 views and not one answer
IF ... you had a Chevrolet V8, I would have the answer ( Gates # 20225 ) but as a MODERATOR here I will bring your question back to the top in hopes of a member seeing this and answering
Old 08-11-2011, 01:42 PM
Tried several forums with a hit for the upper. I even emailed the tech department at Griffin and never even got a reply from them...great customer support
Old 08-11-2011, 01:45 PM
302 Z28's Avatar
Take piece of welding wire or at least a straightened coat hangar and bend it to the approximate shape needed. Measure what diameter you need and with a tape measure trot down to your local auto parts store and ask the counter person if you can look through what they have. That is exactly what I did with my 34.
Old 08-12-2011, 08:56 AM
Exactly right. might need to by a few hoses and then take back what you do not need. Most auto parts stores will not have a problem with that. Be sure to pick an auto zone type cause they will have a large selection. Your problem is not unusual by any means, that is hot-roding.
Old 08-14-2011, 11:08 PM
bentwings's Avatar
bentwings
I just got an 1 3/4" u-bend and cut it up and welded it to fit. I had a snake of a hose so I just cut off a few inches of straight on each end and used that to connect the new "hard pipe". I did run a nice weld bead about 1/4 in in from each end. I used double hose clamps on each end....got that from the boat guys.
This makes a nice smmoth bore "hose" with less restriction and it looks nice.
The big rig trucks use this method too. I just repaired one that had rubbed a hole in it ........after a million miles.
If you really wan to get fancy you can do it in stainless and buff it.
Old 08-15-2011, 08:11 AM
After a couple more hoses I finally got this dilemma solved. Ended up with a 1993-94 ford E350 upper hose Dayco p/n 71556. Triimed it at least 4 times and managed to get an exact fit Thanks to all for your help. now onto another problem
Radiator Lower hose que. on 350 engine 39chevy Engine 3 07-20-2008 09:58 AM
Cramped Space for Lower Radiator Hose JohnTN Engine 3 10-11-2007 08:04 PM
How much lower will the frame lower once the real motor is installed ? Tonythefish Suspension - Brakes - Steering 3 02-05-2007 04:14 PM
Lower Radiator Hose (flex) kinks 1Fast65Elky Engine 9 07-31-2005 05:00 PM
Lower Radiator hose Colapse?? HotRodMan Engine 4 09-06-2002 06:17 PM
