Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lower from Shock stud 1940 Ford Coupe
Old 11-24-2012, 05:37 PM
streetrodderbn's Avatar
streetrodderbn streetrodderbn is offline
Certifiable Streetrodder
The "hot wrench"(torch) will bake the shock rubber bushings(probably set them ablaze) and you can remove the old shocks and you then can reuse the studs and bolts, just have a box of baking soda handy-or water to douse the flames- should it ignite, and keep the flame away from the brake lines-brake fluid is flammable! Then measure the old shocks, I will look on sunday, I think I have a replacement set from Pete and Jakes to steal a part number from for you.
The Following User Says Thank You to streetrodderbn For This Useful Post:
artistsport3 (11-27-2012)
