lowering a 1958 chevy 1/2 ton pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2009, 07:50 PM
im thinking about lowering my 58 1/2 ton truck. my questing is how hard is it to do this? and how much will it cost?
i was thinking about 2 to 4 inches lower than it is now. its completely stock right now.
i dont know much about suspensions.
thanks
Old 01-31-2009, 10:00 AM
It looks like one of the main ways to lower the front is by doing an IFS swap with either the late 70's early 80's Camero or the Mustang II.
Old 01-31-2009, 10:22 AM
poncho62's Avatar
Wiki Edits: 5
Was it still leaf springs on all 4 corners in 58?...If so, lowering blocks, if the axles are on top of the springs. De-arcing the springs if they are under them.
Putting in a dropped axle is another option on the front...
After that, it starts getting complicated.
Old 01-31-2009, 04:09 PM
yes its leaf springs all the way around. and they are on top of the axles. so lowering blocks sounds like the easiest way to do it.
one more question. im putting a 400-500hp engine in it. will i have a problem with the rear axle braking off? its not a drag truck. just a weekend street truck. i dont want to have to find new leaf springs and whatever else brakes when that happens. should i reinforce the axle?
1948-1954 Chevy 1/2 ton Trucks NickO Hotrodding Basics 13 06-10-2011 03:38 PM
Disc brake conversion on a 1980 chevy 1/2 ton pickup junkman Suspension - Brakes - Steering 12 02-16-2009 04:33 PM
1948 1/2 ton Chevy Pickup gorafarm@hotmail.com Introduce Yourself 3 11-26-2008 01:18 PM
what manual trans for 1/2 ton chevy????? kuhn-77 Transmission - Rearend 3 07-28-2007 01:20 PM
Frontclip for a 37 Chevy 1/2 Pickup joerg-kali Suspension - Brakes - Steering 4 08-01-2006 07:46 AM
