Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lowering a the 1965 f-100
Old 03-14-2012, 05:25 PM
matt167 matt167 is offline
Wiki Edits: 31
Panther ( Crown Vic/ Merc Grand Marquis ) front end's bolt in. Rear, you can flip the rear axle ontop the springs and lower that way.. I guess you could heat and bend the original beams to correct a little camber from a coil or 2 removed as there forged, but lowering a '65-'96 twin I beam truck is not cheap
