Lowering - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2011, 08:04 PM
Oldskool88's Avatar
Last journal entry: Hotrod buick
Lowering
Hi guys, i have a 76 F100 stock supension looking at lowering it around 1 to 2 in, looking at doing it right. What would be the best way?
Old 07-19-2011, 08:26 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
76 F150 would be twin I-beams, to do it right would be new dropped I-beams...$$
Altering or replacing the springs causes camber issues.
Old 07-20-2011, 08:03 AM
Oldskool88's Avatar
Thanks also looking at making it a street strip truck, so I don't want to slam it, how would I do the rear for the drag strip
Old 07-20-2011, 08:10 AM
"Flip your rear axle". You can buy different size lowering blocks that will fit the underside of your axle. If you're going 2" in the front, I would recommend a lowering block with virtually no drop. This will allow your springs to rest against the underside of your axle, and will provide a fairly level stance. Too much drop will give you a tail dragger.
WP
Old 07-20-2011, 05:52 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
WP
Dont know about a 76, but with my 65 there isn't enough room to flip the axle. I am going to build longer rear shackles and relocate the forward hangers to lower the rear of my truck. As to the front, you can install drop beams, but what I plan for my truck is to re-drill the inner pivots as high as possible (about 3/4"), and adjust the front spring down until I am happy with the camber. I suspect I can get about 1 1/2"-2" doing it this way. NASCAR weight jacks on the spring pockets would work well for this application.
Andy
Old 07-22-2011, 12:45 AM
With your F100 springs, you can cut 1.5 coils and you should be fine, if you have a alignment shop that can bend your beams in place or cold bend them, you can cut 2 full coils and trim the snubbers a bit....prob give you over 2 inches.
First do the 1.5 coils and see how you like it.
Old 07-22-2011, 05:30 AM
Oldskool88's Avatar
Thanks for all The help the drop ibeams I was looking at are about 500 bucks is that about what they cost.
Old 07-22-2011, 09:20 AM
Yes,in that price range, search ebay.....
http://cgi.ebay.com/ebaymotors/Ford-...item53e836d3ef
or Summit, it's an easy install plus you can still cut the coils for more drop.
lowering my s-10 JJ350 Suspension - Brakes - Steering 1 03-23-2007 04:22 PM
Help with Lowering hot-rod-ford Suspension - Brakes - Steering 3 10-15-2005 09:10 PM
Lowering the '39 RodFather Suspension - Brakes - Steering 3 11-14-2004 07:48 PM
car lowering rustyrazer Hotrodders' Lounge 5 11-02-2002 04:52 AM
Lowering C10 Suspension - Brakes - Steering 7 09-17-2002 08:00 PM
