Lowering 2nd Gen Camero - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2002, 04:13 PM
Cool Lowering 2nd Gen Camero
Which is a better way to lower the front end of my '75 Camero and still keep the ride geometry 1) 2" drop spindles or 2) cut the springs a few coils? Also what about header and exhaust clearance. Do I need to use block header and new piping?
Old 06-03-2002, 04:20 PM
CARGUY's Avatar
Post
dont cut the springs your asking for a broken ball joint go with spindels
Old 06-04-2002, 06:36 PM
Lou's Avatar
Lou Lou is offline
Last journal entry: some more body shots
Post
I like the spindles BUT, you are going to run into header trouble. The headers on that camaro are low I've taken headers and made them shorter so there is better ground clearance. Or you can call Sanderson Headers they make a shorty header. Let me know how you turn out. I'm not far from you
Old 06-04-2002, 08:03 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
They are all right, go with the spindles. get some blockhugger headers, or the ones from henderson, or you could make your own. I have a rat '72 and I put the spindles on and made my own headers. Also unless your going nostalgia, look into some 17" rims and tires, 17x11's on the rear look amazing, and enhance grip dramatically.
Faust
Old 06-06-2002, 09:12 AM
F-1Rodder's Avatar
Post
No question, dropped spindles.
