Lowering '37 ford coupe
My '37 ford coupe has a Fatman front suspension and I would like to lower the front end one inch. I have not weighed the front end, but the coupe is all steel and body is stock, running a chevy 350 motor. I am thinking about cutting one coil on the front springs to get it down an inch. OK or bad idea? Other suggestions?
Thanks |
are these the stock style MII coils?
Do you have dropped Spindles on it?
cutting springs is always a bad idea. buy a set of shorter springs. keeping in mind the grille chin pan is the lowest part of the car.
Lowering '37 Coupe
The springs are stock style MII and not running dropped spindles. If cutting one coil is a bad idea where would I get shorter springs?
If it were me, I'd buy a set of dropped spindles-you will keep you current spring rates (meaning, ride quality)-if you go with shorter springs you will lose suspension travel, which usually means you will up the rate of the springs-that will make the ride more harsh (generally)-
http://www.fatmanfab.com/images/optionshub2hub.jpg (bottom of page)- |
Lowering '37 Coupe
Thanks for your opinion. I appreciate it.
I would call fatmans, they have a chart for the different springs for the weight of the car
make sure you have the correct ones first you can cut a coil, if your budget is super tight but the best way would be to go for the dropped spindles |
lowering '37 ford coupe
On my coupe the distance between the bottom of the grille and ground is currently 6 1/4". If I go to 2" dropped spindles the distance between the bottom of the grille and the ground would be 4 1/4". I currently have P185-70R-14 wheels/tires on the front. Anyone have theirs this low without trouble hitting on driveways, speed bumps, etc.? I guess I could go to a taller front tire, but again that's $$. Is 4 1/4" asking for trouble? I am a pretty careful driver.
lowering 37 ford coupe
do you mean a 1" taller tire?
i would advise you check prices on 37 grilles. at 4 " you will need a few.
Biothree, thanks for your thoughts. I get it about checking tire heights. And, Shine, you are probably right, and your reply made me smile. I do have another nice original grille, but don't want to use it to replace one that being stupid caused it to be needed.
| lowering an 86 ford 1 ton | Fordy8man | Suspension - Brakes - Steering | 6 | 07-18-2009 09:46 PM |
| Lowering the CR on a 2.5L ford | jesshwarren | Engine | 2 | 02-13-2005 10:09 PM |
| ford lowering | martion | Suspension - Brakes - Steering | 1 | 05-27-2003 05:55 PM |
| lowering a top on a 31 ford coupe | rov,nmechanic | Body - Exterior | 2 | 04-01-2003 09:21 AM |
| Help On Lowering My Ford 91 Ranger | Brian Z-24 | Suspension - Brakes - Steering | 2 | 01-09-2003 05:57 PM |
