Lowering 66 Fairlane - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2003, 02:08 PM
Hola...
Having a hell of a time finding anything helpful. My old man (who was lowering rods in 1950) suggested longer shackles for the rear, which is fine, but I can't find a resource for 'em anywhere. Is putting in lowering blocks a decent alternative?
Any ideas, etc. are greatly appreciated.
Thanks
Old 08-25-2003, 03:35 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
have the rear springs de-arched & get shorted progressive coiled front springs. its the only way I know how to do it w/your car, unless someones knows something I dont..........joe
Old 08-26-2003, 06:47 AM
*rubbing chin*
Aye...I got no problems doing the front. I found some lowering kits after poking aroun dhere last night for about an hour. They use the lowering blocks, so I'm guessing that ain't gonna be a huge deal.
Thanks
Old 08-26-2003, 08:35 AM
woodz428's Avatar
Troll Hunter
Arrow
You'll want to be careful lowering the front, with the suspension design you could get the upper balljoints in a bind.
Old 08-26-2003, 10:01 AM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
You can take out one on the leafs in the spring if there are multiple leafs (take out one in the middle). The only thing with the blocks is that if you go with anything over 2", make sure it has the angle build into it to keep the pinion angle correct. Also, to keep it legal (at least here in CA), make sure nothing hangs below the rim.
Old 08-28-2003, 06:41 AM
Killer...thanks for the replies. I'd considered removing the middle spring, too. Though, that was sorta last on my list of options.
Appreciate it.
