lowering 67 camaro?? help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2006, 05:22 AM
DEUCE
what is a good cheap way of lowering a camaro???
Old 08-09-2006, 06:08 AM
Will I ever get it done?
Last journal entry: Driver's Door
Let's see. Good Cheap and Lower all in the same sentence.
Let the air out of the tires?
Sorry. I just couldn't help myself. IMHO if you can't afford to do it correctly, you will be disappointed with the results. Buy some dropped spindles.
Old 08-09-2006, 06:47 AM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
LMAO @ Let the air out of the tires?
Actually, you could cut 1/2 - 1 coil off the front springs or you could buy lowering springs.
Old 08-09-2006, 08:20 AM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
the cheapest way is cut springs and lowering blocks in the rear. takes about 3hrs, $40 for the block kit, and no looking back.
Old 08-09-2006, 09:16 AM
Wiki Edits: 31
actully I did see a vehicle at a carshow that was lowered on airbags but they also let all the air out of the tires. it was the red and black 1939 studebaker truck from www.1939studebaker.com. had me confused as to why.
Old 08-09-2006, 01:10 PM
DEUCE
the tires are flat..lol still to high, where can i get the blocks ?
Old 08-09-2006, 01:23 PM
CDJr's Avatar
Experienced Amateur
Wiki Edits: 2
Summit, Jegs, just about anywhere actually. You can probably even buy them at your local parts store. Just make sure you get ones thatll fit your car, cuz they come in different sizes and configurations.
Old 08-09-2006, 02:44 PM
1969NovaSS's Avatar
pep boys usually has them in stock
Old 08-09-2006, 07:40 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
True, but don't forget that lowering blocks will accentuate spring wrap-up and wheel-hop significantly. It's cheap, but special rear springs are the best bet.
Old 08-11-2006, 10:31 AM
DEUCE
thanks for the onfo .. that helps
Old 08-11-2006, 12:38 PM
I did an economy lowering on a firebird by cutting a coil from the front and taking the rear springs apart and removing some of the arch in a press.
No parts, just some labor.
Bob
Old 08-11-2006, 06:51 PM
Old Camaros and Novas will lower their own rear ends all by themselves. Some folks call it spring sag, I call it incredible foresight.
67 camaro Pats67camaro Introduce Yourself 3 07-04-2009 08:59 PM
A kids dream car. Now it's mine 67 camaro Deon Shouse Introduce Yourself 3 04-01-2006 04:59 PM
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 12:30 PM
67 camaro rearend 72 Z28 Transmission - Rearend 2 02-09-2004 05:53 PM
67 Camaro steering & brakes Jim Vines Suspension - Brakes - Steering 5 01-31-2003 04:36 PM
