lowering an 86 ford 1 ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2009, 08:15 PM
Fordy8man's Avatar
i need some advise on lowering a 1986 ford f350 2wd. its got the i beam front end in it. has anyone done this before. can i flip the i beams over and shorten the springs. whats the best way to go about this.
thanks
Tim
Fordy8man
Old 07-18-2009, 08:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
thanks
Tim
I have never lowered a F-350 , But have done a few rangers with them you can get different I-Beams, So i am thinking You will probably have to buy aftermarket I-Beams, either cut or buy lowering springs. Lowering spring would be best but most people cut the springs. I done some resarch and you should really check out some of these kits out there , check groundforce , look on ebay for lowering kits and you can see several different co to check out,. I do know whatever you do don't just start cutting or heating to get it down the best way is to buy a kit and do it properly. Saftey First. Cole
Old 07-18-2009, 08:44 PM
Wiki Edits: 31
you'll have to get some drop beams, lowering springs and probably some camber bushings.. you can adjust out the camber about a 1" drop with stock beams but that's it.. you could try 2" but you'll likely run into issues
Old 07-18-2009, 08:51 PM
eloc431962's Avatar
Wiki Edits: 37
Yea, it will change the camber when lowering, so you will need new camber bushings to change the degree . Cole
Old 07-18-2009, 09:02 PM
Fordy8man's Avatar
where can i find the drop i beams. and i wouldnt attempt to heat and bend the beams bucause i know id never get them perfect enough to be right.
Fordy8man
Old 07-18-2009, 09:29 PM
Ford Junkie's Avatar
No substitute for cubic inches
If I remember correctly (and that's questionable sometimes) if you just want a couple inches that you can buy 2" dropped spindles for this truck. I do know that with the beam front end that anything over 3" s gets alittle screwy with the drag link and tie rod because they run through the trailing arms and there's only so much room for movement there. Google drop ford spindles and I think you'll find a few that offer them.
Not much help but hopefully some,
Tony
Old 07-18-2009, 09:46 PM
Wiki Edits: 31
DJM sells the beams.. Belltech may have spindles but they would need to be for an '86.. they changed the spindle setup in '87 IIRC... 3" drop in the rear can be achived by flipping the rear hangers
Early Ford Spindles fitting early Ford axles pasadenahotrod Suspension - Brakes - Steering 3 08-14-2012 07:20 PM
Lowering a 1960 Ford Pick up rushlow Suspension - Brakes - Steering 2 11-14-2011 11:27 PM
1980 Ford 3/4 ton 4x4 with 1969 ford body d&c repairs it all Body - Exterior 16 06-12-2009 01:18 PM
'41 ford, 1 ton, spindle to spindle measurement 41 ford stakebed Suspension - Brakes - Steering 2 07-13-2008 05:39 PM
Lowering the CR on a 2.5L ford jesshwarren Engine 2 02-13-2005 10:09 PM
