Lowering arms or drop spindles?
I'm using Chevy C10 front suspension parts to rebuild my '37 Buick Roadmaster.
DJM offers lowering control arms for $737 and drop spindles for $310. http://www.djmsuspension.com/applica...s/C10Parts.htm The control arms have improved geometry for, but I should be able to make some of these improvements when we design the mount brackets for the arms. 1) If I only only want 3" drop, am I better off with the new lowering control arms or the drop spindles? 2) Can anyone share the pros & cons of each approach? Thanks |
iirc the arms are to keep the engine crossmember and arm mounts(at crossmember) above the scrub line. if use'n tall tires or big rims(17"+) it's not much an issue with spindles..
if you are making the arm mounts, you don't need either. you can run 3" drop springs, and fix the alinement issues that come with them ,because you are fabing the mounting points |
I'd get the stock spindle andarms and mock it up and see.. the c-10 whole set up bolts in/out of the truck. why not just slice and dice it in.. and use it's spring pocket..
I am still considering using the complete C10 cross member because it mey be less fab time, but I have a couple of reservations on this approach:
a) I think the cross member will add lift to my car because the Buick frame will have to be bolted/welded to the top of the cross member. b) By designing a custom upper bracket I can move the upper spindle back and add caster that I do not thing the truck cross member will have. Using a stock C10 cross member would probably be less risk and make the fabrication. 1) Do you think the ease of installing the stock cross member and reduced risk would out-weigh the disadvantages? Thanks |
no idea, as I don't have a 38 buick to look at,, only a 71 c-10
| drop spindles | caletcb | Hotrodding Basics | 3 | 12-09-2009 04:02 PM |
| Drop Spindles | 63CustomCab | Suspension - Brakes - Steering | 3 | 01-22-2008 09:20 PM |
| Lowering Springs AND drop Spindles?? | naraah501 | Introduce Yourself | 1 | 11-11-2004 10:43 PM |
| drop spindles or lowering springs | Echofive | Suspension - Brakes - Steering | 7 | 04-28-2004 06:01 AM |
| Drop spindles and lowering springs | scott ticknor | Suspension - Brakes - Steering | 1 | 11-25-2003 05:51 PM |
