Lowering Blocks - 10 Bolt MultiLeaf Perch - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2007, 12:59 PM
I would like to drop the rear of my '69 Nova by using 1" blocks in the perches. First of all - is this an OK idea? Next, what hardware would be used? The original setup on the 10 bolt used one U-bolt and two "T" bolts. Obviously the shock mounts won't clamp up against the perches with the block in there, so what's the best way to go? Thanks.
Old 02-16-2007, 02:27 PM
50 chevy p/u's Avatar
autoglass master tech
You should be ok. Just replace the 2 bolts with u-bolts. You'll need longer ones , so measure and go to a spring shop and have them made.
Old 02-16-2007, 05:04 PM
Chopt 48's Avatar
50-Chevy pickup has it right, there should be a spring shop in any larger city close to you. You can also get new u-bolts at NAPA and they arn't too spendy. I'd take one of yours along and tell them that I needed 4 that are X" long
On second thought, check to make sure that u bolts will go straight down on the side with the T bolt you may have to do a bit of modification there.
there is something different about where the bolt holes are on the side with the T bolts but without looking at one I can't remember what. Nothing you can't work around but you may have to modify the plates with the holes a bit.
Old 02-17-2007, 10:51 AM
Thanks. We'll see what unfolds when I put it all back together.
Old 02-27-2007, 01:37 AM
There's no problem going from T-bolts to U-bolts. My '69 had T-bolts all around (6-cylinder car), and I bought 4 U-bolts for a V-8 application from GM and used them in the same holes with no mods necessary.
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 08:19 PM
68 Camaro 10 bolt & 2000 truck limited slip 68CaliCamaro Transmission - Rearend 6 12-22-2003 04:57 PM
GM 8.5", 7.5" 10 bolt ?? and 700R4 ?? williemon Transmission - Rearend 4 12-16-2003 03:11 PM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 11:22 AM
How Strong is a Chevy 10 Bolt Rearend bigjoedo Transmission - Rearend 3 04-07-2002 05:04 PM
