Lowering blocks.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2008, 07:26 AM
Lowering blocks....
Hi all,
I've got the Chassis Eng. parallel leaf kit in my 36 Ford and need to drop it 4 or 5 inches. I know them poor, misguided 4x4 guys run crazy amounts of lift blocks but is there any down side to too much lowering block??
Thanks,
Cam
Old 03-06-2008, 07:41 AM
Last journal entry: Journal Update
Lowering Blocks
The down sides are scrub line and pinion angle. Keeping those items in check it should not be a problem. I have dropped my 50 chevy 4" with my own home made lowering blocks, adjusted the pinion angle to keep that in check and lastly (which I have not done yet) is cut the U bolts shorter to keep the scrub line in check. I plan to remove some leafs from the brand new OEM springs to lower it a bit (that's why the U bolts have not been cut yet). Hope that helps. If you are not sure about the scrub line and pinion angle, do a search on here. There is tons of information.
-Sonicweb
lowering blocks and traction bars?? 47chevrolet Suspension - Brakes - Steering 4 09-28-2007 02:53 PM
Lowering Blocks? 39chevy Suspension - Brakes - Steering 2 08-21-2007 08:48 AM
Lowering Blocks - 10 Bolt MultiLeaf Perch nova69 Suspension - Brakes - Steering 4 02-27-2007 01:37 AM
front lowering blocks?? suedespade Suspension - Brakes - Steering 8 02-14-2007 08:36 PM
Lowering Blocks Chevy535 Suspension - Brakes - Steering 4 07-27-2006 03:33 PM
