your not going to find any kits for a car like that.. 2-3" would be easy with lowering blocks and shorter coils in front, but I think the '54 Packard uses king pins instead of balljoints, which will throw off the Camber.. you would need dropped spindles then, which I do not belive are available. and at that point you would need to do a front clip on it..
You obviously have to pay attention to clearances, etc. but doing this- along w/the other suggestions- will make a noticeable difference. A much more radical approach that's often used by rodders, is to remove the front frame and replace it w/a late model subframe. This gives a couple benefits- engine mounts for a modern V8, disc/power brakes, improved steering (either late model OEM or R&P), lowered stance, better ride, etc. |
If you could post a photo of the front suspension, there might be other alternatives to just cutting coils or a sub-frame. I have lowered many odd ball (no offense) suspensions by altering the control arms. If you step the lower arm and re-angle the upper ball joint mount as required you can relatively easily lower the front end 1-2 inches. That process along with cutting the springs slightly a 3" drop or more is possible and still be able to align the car. The rear is easier with either lowering blocks, or different spring hangers.
Andy |
| 700R4 – Why are the TCI manual valve body instructions so lousy? | Bayley | Transmission - Rearend | 24 | 02-16-2009 12:49 PM |
| I need help mounting a body to frame where it does not belong! (pics inside) | fiscus | Body - Exterior | 9 | 11-27-2007 05:41 PM |
| Sprayable Body Filler | robs ss | Body - Exterior | 10 | 11-19-2007 06:56 PM |
| How to on Body Off Build? | joeford | Hotrodding Basics | 3 | 05-09-2006 07:29 PM |
| Body off question... | joeford | Hotrodding Basics | 1 | 05-07-2006 07:26 PM |
