Lowering - Camber issues
I want to lower my 49 Lincoln (Mercury). Primarily with a set of Air Ride Tech Cool ride and Airover springs - air bags. But also I want to use 2" Fat Man drop spindles to avoid camber issues associated with just using cut springs/extracted leafs/blocks etc. (I will use a combination of those in addition to the spindles and air bags.) But I'm trying to figure out how low I can go without camber issues. How much extra camber adjustment do I receive by adding the drop spindles? I know it's probably 2".
But if I knew how low you could go without camber issues - not using the dropped spindles - I assume I could add 2" to it with the use of the dropped spindles. And I'd have my final answer. And could make out a complete parts list. I've read the many threads concerning lowering on the forum. Anyone know how low you can go without camber issues forcing the use of the dropped spindles on a 49-51 Merc (same thing as my Lincoln as far as I know)? The rear is just an issue of welding in a larger drive shaft tunnel into the floor pan. Which is quite shallow to begin with - 7" clearance at the rear. But only a few inches of bump in the floor pan. So I can raise it quite a bit before turning the floors into Mt. Everest. Any help prior to ordering a bunch of parts would be greatly appreciated. 49' Lincoln |
| How to remove coils from 96 EL Ford Falcon | boofis | Suspension - Brakes - Steering | 17 | 02-03-2005 12:09 AM |
| bad family issues | akm | Hotrodders' Lounge | 18 | 06-18-2004 11:19 AM |
| drop spindles or lowering springs | Echofive | Suspension - Brakes - Steering | 7 | 04-28-2004 06:01 AM |
| Lowering 66 Fairlane | Boner | Suspension - Brakes - Steering | 5 | 08-28-2003 06:41 AM |
| lowering an 88 thunderbird | FoxThunder 5.0 | Body - Exterior | 1 | 06-28-2003 02:25 PM |
