Lowering the CR on a 2.5L ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2005, 09:33 PM
New Member
I got a 98 ford ranger with a 2.5L I am currently installing a turbo kit on it. The cr is 9.4-1 on these motors I don't whant to have to tear the motor down to change pistons. I was wondering how thick I would need to go with copper headgaskets to get it down to 8.5-1.
The pistons in it now are the stock hyperutectic pistons wich are said to be able to handle boost.
Old 02-13-2005, 09:37 PM
lluciano77's Avatar
Short changed on common sense
Shimming it to reduce compression will make things worse.
http://www.speedomotive.com/Building%20Tips.htm
Try running it with what it has.
Old 02-13-2005, 10:09 PM
Max Keith's Avatar
compression
I dont recommend doing the gasket job either. Instead, have your pistons turned down >025-.030".
