Lowering Fat Fender Street Rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2011, 11:46 AM
Mutt's37Buick's Avatar
I'm just starting plans for transforming a stock 1937 Buick Sedan into a street rod. Current plan is to install a Mustang II front suspension. Would anyone out there be willing to share pictures of similar fat fender street rods and what the running board height (front and back) is? What wheels, tires, drop spindles, and suspension components were used to accomplish your results?
Thanks,
Mutt's37Buick
Old 03-23-2011, 01:18 PM
spacytracy's Avatar
Last journal entry: 1957 Chevrolet 3100 Truck Small Window to Big Window Conversion
1937 buick ride height
Send me an email and I will shoot some pictures of my 38 chevrolet coupe. I used total cost involved mustang 2 with 2" drop spindles and posies super slide rear springs and added in 3" lowering blocks.
jhanmiller@comcast.net
Old 03-24-2011, 08:11 AM
327NUT's Avatar
Just a warning...if you use a MII front end make sure you buy a QUALITY kit like TCI or Heidts for example. There have been some major failures from lessor known manufacturers resulting in accidents and injuries. The MII kit HAS TO BE built and installed properly, that big old Buick is a heavy car.....and I would keep it all Buick with a built Nailhead or 455.
Old 03-24-2011, 02:00 PM
Thanks for the advice. I have also heard good things about Fatman Fab.
Old 03-25-2011, 10:16 AM
S10xGN's Avatar
Gotta love a turbo!
Here's a pic of my '47 Ford (long-term) project. It's a mix of stock boxed rails, Progressive Automotive's "sweet-ryde" Corvette coil-over front clip and center section, and 2x3 rectangular tubing in the rear with a narrowed Ford 9" axle. There's 7" under the 'boards and the rear needs to come up another inch or two...
Russ
Old 03-25-2011, 10:25 AM
Hi s10xGN,
Is the 7" under the running boards as it sits, or with everything installed.
What is your target height under the boards.
Old 03-27-2011, 01:10 PM
S10xGN's Avatar
Gotta love a turbo!
Originally Posted by Mutt's37Buick
Hi s10xGN,
That was with a complete aluminum block LS-1 and 200R4 installed but no interior. No particular target, just going for "the look"...
Russ
Old 03-28-2011, 08:51 PM
Thanks for the info
Old 03-29-2011, 09:43 AM
302 Z28's Avatar
That is one of the one's that has been involved with some failures.
Vince
Old 03-29-2011, 01:28 PM
Thanks for the heads up. I'm still reviewing many threads related to this. I'm a pretty conservative guy and want his to be a safe ride to haul my family around in. Still researching.
Old 03-29-2011, 02:08 PM
302 Z28's Avatar
A couple of years ago the forums were abuzz with pictures and discussion about an incident where a MII front end failed and caused a wreck. It was alleged that the front end was a Fatman's. I don't remember if it was ever determined if the owner installed it or not.
Vince
Old 03-29-2011, 02:15 PM
Those are some of the threads I've been reviewing. If you want to see others responses check out our conversation on a thread under suspension called "1937-1957 Buick Oldsmobile Pontiac suspension upgrade".
Thanks
Street Legal Pro Street Cars mrmustang312 Introduce Yourself 1 11-11-2008 10:58 AM
Tire Cover as Fender?(cycle fender), Need Bracket Ideas! Fred A Body - Exterior 1 01-29-2006 03:46 PM
Have you used this fender tool? "fender extender" myfamiliacc Body - Exterior 4 06-01-2005 09:27 PM
770 Holley street avenger or 750 BG Street Demon Shawn Horan Engine 8 04-03-2004 09:23 AM
37-39 rear fender welt/ fender repair? jcarter Body - Exterior 8 02-17-2004 08:41 PM
