Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lowering the front clip of a 1969 chevy nova
Old 09-12-2011, 11:55 AM
ethn_bert ethn_bert is offline
Last journal entry: Some More Roll Cage Fabrication
As long as the springs are installed into the pocket correctly. Did you use the "witness" holes to ensure that the springs are aligned correctly?
Also, you might want to get an alignment check; that much change in ride height guarantees an alignment is needed.
Good luck.
