Lowering front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2007, 03:13 PM
Lowering front end
I have a 28 Model A w/Mustang II front suspension and would like to lower the front end a bit. I currently have P185/75R14 tires on it and since it is time for new rubber now would be the time to lower it. My question is if I change to 175/65R14 or P175/70R14 what would be the reduction in ride height? I don't want to go to 60 series tires because I have motorcycle style fenders on the front and I don't have the room for wider rims w/o remaking the front fenders.
Thanks - Jerry
Old 01-23-2007, 03:23 PM
I don't think that you can get a definite answer except from your tire dealer. We had a rubbing problem on a friend's 40 Ford. He switched brands of tires on front, stayed with same size, kept same wheels, and the problem was gone. Best way to find out about height difference is to ask your tire dealer. I've always been able to get them to experiment with different sizes till we get what we want on my cars. Good luck........hope this will help you a little
Old 01-23-2007, 03:56 PM
boatbob2
lowering" A " model ford
Hi,theres 1 way you can lower the "A",buy 2 inch lower spindles for you mustang 2.
Old 01-23-2007, 04:09 PM
Yup, dropped spindles are available for MII front ends, but the question was about tire size for the rubber rake. Dropped spindle will definitely drop the front end.
Old 01-23-2007, 04:27 PM
steve t's Avatar
ex biker, now hotrodder
you can mureasure tire at store, but i dont think the change of tires will give you what you want
Old 01-23-2007, 04:38 PM
The Maintenance Geek
go to the tirerack, http://www.tirerack.com/ and select
you present tire, write down the diameter, select another
size tire, how much shorter is it, 1/2 that dimension will be
how much lower the front end will be...
K
Old 01-23-2007, 09:30 PM
Lowering front suspension
Bates K - Thanks for the link, it gave me the information I need. To the rest of the guys thanks for your help, as to the dropped spindles, that would have been to much of a drop.
Thanks - Jerry
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 07:03 PM
Got 39 Poncho, have front end questions rwruther Suspension - Brakes - Steering 0 05-23-2004 02:32 PM
Corvette tilt front end? shovelrocker Body - Exterior 4 01-13-2004 05:55 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 07:10 PM
