lowering front of engine (67 mustang) - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2010, 06:53 PM
is this possiable on a 67 mustang? i have tunnel ram. it looks bad at that angle. i like the look of tunnel ram i know it would probably make more power with a single carb. i see these adjustable motor mounts. they look like they just go side ways and forward and backwards. i have a t5 trans. also worried about driveshaft angle.
Old 11-27-2010, 06:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I wouldn't even think about lowering the front of the engine in that car. And for what reason other then the angle that you will see the tunnel ram. I don't think so but it's your ride.
Change the stance of the car but not the engine angle.JMO
Cole
Old 11-27-2010, 07:21 PM
68NovaSS's Avatar
Wiki Edits: 9
I would think changing the engine angle will also change the intake plane, possibly causing unequal cylinder distribution and/or carb float issues.
Old 11-30-2010, 01:03 AM
fordsucks7's Avatar
it really isn't the hardest thing my moms x did it on her 66 mustang when we where putting the 302 in it cause the hood wouldn't shut he just cut the crosmeber out fabricated a newer one for the aod trans. Made engine mounts from prob 3/8 of an inch think steel and just put the wholes where they mounted lower these guys just make it sound more confusing
Old 11-30-2010, 06:04 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
I wouldn't drop the front also.. Thats not the way to fix it.. Like said already, You will change two many other things, And will make other problems..
Old 11-30-2010, 08:11 AM
I'm about done building a 65 and you can hardly slide a sheet of paper between the steering linkage and oil pan. I don't see it as a worthwhile option in my case.
Old 11-30-2010, 12:52 PM
i am trying to post a pic. i dont know how to make it small enough. this motor looks to me that it slants backward alot. i put a t5 trans in and wondering if i did something wrong. i dont want to change it if nothing is wrong. this is the 1st ford i have ever built.
Old 11-30-2010, 01:44 PM
bigdog7373's Avatar
Of course it's fast
On almost every car the engine isn't perfectly level or centered. In my car mine sits a little higher in the front and is offset slightly to the drivers side. Post a pic of it.
Old 11-30-2010, 02:29 PM
eloc431962's Avatar
Wiki Edits: 37
The tunnel ram is designed that way to give the best air flow. JMO
That's why they lay back the way they do it's in the design.IMHO
Cole
Old 11-30-2010, 02:32 PM
Put a level on your carb base on the intake and see where you are now.. I set them up level off that base..
Old 11-30-2010, 04:45 PM
i got a pic to up load. will put level on it tomorrow.
Name:	Misc Sept & Oct 2010 061.JPG
Old 11-30-2010, 04:47 PM
bigdog7373's Avatar
Of course it's fast
It looks fine.
Old 11-30-2010, 05:01 PM
I can tell you now,The base plate is not level.. Get a shot with the hood open of the tunnel ram.. I have seen where the top of the tunnel ram was on backwards(Top can be removed) in made everything odd.. If yours is removable..
The headers look to be sitting right.. Thats why I would like to see the tunnel ram pics..
Old 11-30-2010, 05:58 PM
bigdog7373's Avatar
Of course it's fast
I too would like to see a pic with the hood open. You bring up a good point with the headers, there may be something wrong with the tunnel ram. But still, i don't think it looks too bad.
Old 11-30-2010, 10:28 PM
benwantland's Avatar
So you swapped a trans in and your motor sits at a weird angle? Sounds to me like the mounting pad on the new trans has a different height relative to the engine, compared with the old one. This would also f' up your u-joint angles, btw.
I would think that - if this were the case - you could shim the mount or maybe they make replacements that are taller.
67 Mustang Quarter Panel Replacement Morgan22 Body - Exterior 8 07-16-2010 02:30 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
67 Mustang C4 BT74 Transmission - Rearend 10 05-06-2007 12:09 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
