Lowering IFS - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2003, 05:21 AM
Post Lowering IFS
I know that technically a 74IH truck is not a hot rod but when Im done Im hoping that it will be one heck of a sleeper. My question is does any one know how to lower the front end of a truck with IFS other than cutting or heating the springs? There is not alot of aftermarket stuff available and I dont wnt to completely mickeymouse the front end for obvious reasons.
Old 05-29-2003, 05:38 AM
Post
Lower the front end? I don't think so.
The definition of a "sleeper" is a vehicle that appears bone-stock usually down to the stock size wheels and tires but has a heart-stopping, mood-altering, absolutely screaming high HP engine with "quiet" exhaust that allows you to slide up next to an unsuspecting dork in a 5.0 Mustang and blow his freakin' doors off from a rolling start.
The stock size tire thing makes the rolling start much more effective than a smoke-producing sideshow with no forward motion.
Old 05-29-2003, 06:18 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
Post
call some of theys folks they can make a shorter spring that will carry your trucks load...just tell them how much shorter you want them to be & they can be made, had to do it for my bro's 39 Dodge. I f you can find what you need do a "SEARCH" under Automotive coil springs...joe
<a href="http://www.kingsprings.com/" target="_blank">www.kingsprings.com/</a>
<a href="http://www.drivetrain.com/emucoilspring.html" target="_blank">www.drivetrain.com/emucoilspring.html</a>
<a href="http://www.industrialsprings.com.au/form1.htm" target="_blank">http://www.industrialsprings.com.au/form1.htm</a>
<a href="http://www.springs-compression-coil-gas-torsion.com/AUTOMOTIVE-COIL-SPRINGS.php3" target="_blank">http://www.springs-compression-coil-gas-torsion.com/AUTOMOTIVE-COIL-SPRINGS.php3</a>
<a href="http://www.espo.com/" target="_blank">http://www.espo.com/</a> 1-800-903-9019
<a href="http://www.dendoff.com/prod_auto.html" target="_blank">http://www.dendoff.com/prod_auto.html</a>
<a href="http://www.bluecoilspring.com/rate.htm" target="_blank">http://www.bluecoilspring.com/rate.htm</a>
