Lowering my F-150 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2007, 09:50 AM
Lowering my F-150
I wanna lower my 95 Ford F-150.. 5" in the rear (that dont sound right does it ) and 3" in the front. What kit should I use and where can I get it? I know Fords are a little funny with the Twin I-Beam suspension and all.. I just wanna make sure I do it right, dont want my front wheels kicked out at the bottom, I've seen this on a lot of fords.
Old 10-07-2007, 06:47 PM
cboy's Avatar
Last journal entry: Finished
The rear you can lower a number of traditional and inexpensive ways. The front is the real challenge. To do it right you'll need dropped axles (pricey) or dropped spindles (also pricey). I think Summit has the dropped axles so you can check the prices there.
Always learning...and sharing what I've learned.
Old 10-08-2007, 03:43 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Wait... a 95 F150 has Ibeams??? I just lowered my buddy's 99 F150 and it was traditional control arms. We put coils in it.
Old 10-08-2007, 05:05 AM
65-96 Twin I-beam.
You can get aftermarket beams for lowering.
Larry
Old 10-08-2007, 10:41 AM
jvsutton's Avatar
Bean Counter
Last journal entry: Paint time
Yea new beams is the only way to get it down and keep geometry correct. No one makes drop spindles. The good news is at least for the newer trucks they are cheaper. Beams for my 77 are like $550, I think for newer trucks they are only around $350!
Old 10-21-2007, 08:01 PM
Definitely drop beams.
I think 5" in the rear you might need C notches.
Lowering 67camarokid Suspension - Brakes - Steering 2 06-07-2006 08:36 PM
How to remove coils from 96 EL Ford Falcon boofis Suspension - Brakes - Steering 17 02-03-2005 12:09 AM
Drop spindles and lowering springs scott ticknor Suspension - Brakes - Steering 1 11-25-2003 05:51 PM
lowering an 88 thunderbird FoxThunder 5.0 Body - Exterior 1 06-28-2003 02:25 PM
lowering springs and handling smallz Suspension - Brakes - Steering 6 06-12-2003 07:07 AM
