Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lowering the rear .
Old 08-27-2002, 10:55 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
Is the axle on top or bottom of the spring? I'm having a mental block. Anyway, I would rather lower at the axle if it were me; put the axle on top of the spring or if it is already there, put some spacer blocks in with longer shackle U-bolts.
